Brush Tool frame by frame
matt kelly
on Apr 16, 2013 at 3:54:55 am
When using the Brush Tool is it possible to see what you have drawn on the previous frame like at a lower opacity? Its annoying having to 1 frame backwards when making frame by frame animations.
Todd Kopriva
Re: Brush Tool frame by frame
on Apr 16, 2013 at 7:03:13 pm
What you're referring to is often called "onion skinning" and, no, there is no feature for doing this in After Effects. If you think that there should be, let us know here:
http://www.adobe.com/go/wish
After Effects team blog
Ollie Inglis
on Apr 17, 2013 at 10:31:20 am
I too had encountered this problem - i was trying to make a brush animation over live action footage. My solution was to import the video into Flash CS6, use the onion skin tool there, then export the brush animation back into after effects and place it over the footage. I takes a bit longer but the overall animation is better i think.
