How do I make a picture moves along a line in after effect?
Sharman Ravintharan
on Apr 11, 2013 at 5:50:31 pm
i have already done the line and the line works perfectly. what i want to do is i want to have this aeroplane effect
plz help me btw i already have 1 path now i want the object to follow the line path
John Cuevas
Re: How do I make a picture moves along a line in after effect?
on Apr 11, 2013 at 6:49:56 pm
How did you make your line animation, mask and stroke? If that's it, just open up the mask and click "mask path".
Now go to your plane, twirl down to position and paste the mask properties into the position. Now adjust the keyframes to match your line animation. Press "Cntl+Alt+O" and change the orientation to "Orient to Path". You may need to adjust your starting rotation but the plane should follow the path after that.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Sharman Ravintharan
on Apr 12, 2013 at 10:01:04 am
i used this tutorial to make my lines so do i still follow the above instruction u gave me thx
John Cuevas
on Apr 14, 2013 at 6:36:13 pm
Pretty much the same, yes. You would twirl open your shape layer > Path > and select "path" and copy it(cntl+c). Now open your airplane layer, and the transform properties and click-select position and paste(cntl+v) the path you just copied. Press "cntl+alt+o" to open the orientation dialogue and select orient along path. You will probably need to rotate your plane to get the correct starting position.
Lastly, when you copy the keyframes from the path, they probably won't the timing of your Trim effect on your shape layer. The pasted keyframes are roving keyframes, so you just need to the first one and move it to where your animation starts and then move the last one to where the animation ends. Because these are roving keyframes the ones in the middle will auto-adjust.
Here's a little project I made illustrating the technique, let me know if you have anymore questions. 5846_autoorientfolder.zip
Thinkck.com
Sharman Ravintharan
on Apr 16, 2013 at 4:06:19 am
bro so far so good thx so much....but i didnt understand what you said in ur second paragraph about the rowing key frames can you explain more about that thx
Sharman Ravintharan
on Apr 16, 2013 at 6:53:33 am
hi again thx so far now the problem is i cant seperate the keyframe as u mention in paragraph 2 when i move the the frames all of the frames moves together i cant seperate just the last 1 and the 1st keyframe
Sharman Ravintharan
on Apr 16, 2013 at 7:11:32 am
http://www.filedropper.com/mapanimation i have uploaded my work here u can see it
Sharman Ravintharan
on Apr 20, 2013 at 11:21:26 am
so is there any way to solve my problem thx
Sharman Ravintharan
on Apr 12, 2013 at 10:01:44 am
