Depth of Field not working!
Ben Hartley
on Apr 9, 2013 at 10:26:20 am
My depth of field isn't working at all. I have a camera and depth of field enabled and final quality enabled also.
Any suggestions? See image.
If it looks good, look at it.
John Cuevas
Re: Depth of Field not working!
on Apr 9, 2013 at 11:50:35 am
How big is your comp, if we are looking at it 3.1% size, just curious?
Try adjusting the F-stop first(use lower numbers, like 4, 3, 2.8...), then the blur level 2nd. AE cameras mimic real life cameras and at wide angles, the depth of field is really deep.
To adjust the F-stop without having to open the camera dialogue, just twirl into the camera options and adjust the aperature to higher numbers, (10, 15....)
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
© 2018 All Rights Reserved
