AE script/comp crashing on render
Joel Arvidsson
on Mar 15, 2013 at 11:47:46 pm
Got an ae comp/script that crash when render. It was an dynamic linked clip that i changed composite durantion on and extended it.
I think this could be the reason for the crashing. The orginal do not crash. Im thinking it can be referensing the dynamic link still even thoe i saved it under a new name.
Its a simple comp with some roto and paint job. I dont think its the paint operattion but It would be my second or third guess. When it crash it sometimes wine about the exposure effect.
Any suggestions. I will force this render tomorrow one way or another.
Cheers
Joel
joelarvidsson@gmail.com
Todd Kopriva
Re: AE script/comp crashing on render
on Mar 16, 2013 at 2:33:49 am
We need to know a lot more if we're going to help you. Please provide answers to the questions listed here:
"FAQ: What information should I provide when asking a question on this foru...
After Effects team blog
Jerome Carter
on Mar 16, 2013 at 10:32:56 am
I have some experience with scripting and after effects, if you want to share your code, I can review for possible syntax, construct problems.
Joel Arvidsson
on Mar 16, 2013 at 4:31:47 pm
Jerome, that was very kind. Sorry I did not mean scripting.I meant the ae projekt file so no scripting.
Joel Arvidsson
on Mar 16, 2013 at 5:06:25 pm
Here is some more data Todd.
I use cs6 ae with the latest update.
Windows 8 proffesional
red r3d 4k file is the source clip.
Some times ae crashes and sometimes I get a error like this
after effect error: crash in progress. Last logged message was:<6624>
<0> Vid rate ratios min, max:1,1
or
After effects error:crash occoured while invoking effect plug-in "Exposure".
or.
After effects error:crash occoured while invoking effect plug-in "indiviual levels".
The problem only comes when im rendering.
I have not had any problem with ae crashing and alot of clips have been rendered with very similar setup.
I have just installed the a blackmagic card but the my first version of this comp have no render probleme. Only the one
i extended the compostion time on to make the clip longer.
No problems on ram previews at all.
No multiple frames rendered simultaneously.
I just think this has to do with that the clip was dynamic linked from premiere to ae. Then I got a to extend that clip later in ae with composition settings time. I think 90% of all error in ae is related to the dynamic link so thats my guess.
Joel Arvidsson
on Mar 16, 2013 at 5:28:53 pm
Its even in ram previews now... didnt se that yesterday
Joel Arvidsson
on Mar 16, 2013 at 6:31:21 pm
1/4 ram preview does not crash, and I know I did 1/2 before. But full crashes.
Joel Arvidsson
on Mar 16, 2013 at 7:32:12 pm
Never found the problem. Had to render it out in segments. Atleast its done.
Todd Kopriva
on Mar 17, 2013 at 12:22:11 am
I'm glad that you were able to at least get your project done. Please submit a bug report here so that we can look into the issue:
http://www.adobe.com/go/wish
