CS6: OpenEXR import and buffer separation?
Eric Chard
on Feb 18, 2013 at 10:48:24 pm
The CS6 documentation says that a formerly 3rd party external plugin, ProEXR, is used to utilize the extra buffers OpenEXR is capable of supporting. And is included w/CS6.
I see the EXtractoR and IDentifier plugins in the Effects menu but not the ProEXR plugin. Where is it accessed?
Thanks.
"Putting the HARM in 'harmonica' since 2005."
Todd Kopriva
Re: CS6: OpenEXR import and buffer separation?
on Feb 19, 2013 at 4:09:03 am
IDentifier and EXtractoR are the ProEXR plug-ins.
After Effects team blog
Eric Chard
on Feb 19, 2013 at 5:29:01 am
I got that now. I must say that's some of the most elliptical documentation I've ever seen.
I'm working w/a 3d app that exports the Shadow buffer, apparently, as just a single 8 bit buffer/layer (no color info) inside the EXR file. In the EXtractoR plugin, what do I assign to the RGB channels to use the shadow buffer as a Multiply layer in AE to implement a shadow?
And what does the "copy" parameter in the channel substitution dialog mean? Copy from the original layer?
Thanks.
