Adobe Media Encoder - AE Challenge
Paul Nanna
on Feb 11, 2013 at 10:19:40 pm
We've been doing digital signage for 10 years now and are using CS4.
All has been well exporting .mov files at an aspect rtatio of 2400 x 600 to fit our 3 panel wide displays (800 x 600 (x3).
We have a client using CS6 who is building his own content.
Appears he is not allowed by the PAR to export at 2400 x 600.
The best it will do is 2000 x 600.
I've installed an eval copy to confirm this and it is true.
What happened?
CS4 allows a direct export to Quicktime even with a pixel aspect set to 1.33.
The new and improved will not allow this.
Anyone know of an "over ride" or custom setting that will allow a .mov (H.264) outout of 2400x600, 1.33 aspect ratio in Adobe Media Encoder?
Tero Ahlfors
Re: Adobe Media Encoder - AE Challenge
on Feb 12, 2013 at 6:45:44 am
Is there a reason you absolutely can't use the mp4 H264 format?
Paul Nanna
on Feb 12, 2013 at 7:45:28 pm
H.254 is the preference.
We tried exporting using th Media Encoder at 2400x600.
It bumps down to 2000x600 for the export.
At one time, a ballon came up saying that the 2400x600(1.33) was out of the PAR specifications and would not be allowed.
Again, with CS4, this was never a problem, although it did not utilize the Media Encoder as a output module that I can see.
Looking to override the Media Encoder settings if possible.
Tero Ahlfors
on Feb 13, 2013 at 5:03:35 am
The Quicktime version of H264 is getting pretty dated. The "proper" H264 mp4 has so much options for encoding.
Paul Nanna
on Feb 13, 2013 at 9:56:55 pm
That would be fine... whatever works.
Again, the problem is that teh Adobe Media Encoder will NOT ALLOW an export video file of the 2400 x 600 size.
It dummies down to a 2000 x 600 output format.
I'll use whatever is available as long as 2400 x 600 can be output.
I'm not codec "centric". It just needs to be a quality codec that doesn't require umpteen gigabytes for a 1 minute video file.
Also...export from Adobe Media Encoder at 2400 x 600 (1.33)pixels aspect ratio.
Tero Ahlfors
on Feb 14, 2013 at 4:47:44 am
Choose H264 from the dropdown menu and choose a high enough profile and level. Then TYPE the values in to the resolution settings because AME might freak out if you drag it to an invalid value.
Todd Kopriva
on Feb 19, 2013 at 9:32:20 pm
If AME isn't working as you need it to work, be sure to submit a bug report or feature request:
http://www.adobe.com/go/wish
You can submit the bug against Premiere Pro or After Effects---whichever one you use with AME most.
After Effects team blog
