Sort of boomerang effect?
Kenneth Gudmundsrud
on Nov 22, 2012 at 4:59:15 pm
Hey, so when I apply ease ease in on a keyframe (straight path), I get a strange animation result, as if the animation path goes around and past my last keyframe before ending at the right spot. I'm not sure it it's the boomerang effect (I've seen Aharon Rabinowitz's tutorials), and the keyframe handles doesn't show anything wrong. I have spatial interpolation set to linear and temporal to bezier, since I want that smooth stop in my animation. This happens every time I try to ease the animaiton of a straight path.
Vishesh Arora
Re: Sort of boomerang effect?
on Nov 25, 2012 at 11:39:23 am
Check in you Graph editor whether the curve for Speed Graph is similar to a hemisphere or not.
Also if you are animating in X Axis, then you should see flat curve shaoe at the starting and end key frame.
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Demo Reel(3D):
© 2018 All Rights Reserved
