Creating a mosaic transition
Oliver Kuusk
on May 13, 2014 at 8:39:28 pm
Hello
I would like to create opening credits in AE with a mosaic transition effect.
Similar like this:
I imagine it can be extremely easy, but as a rookie, I couldn't find a way to do it.
Kevin Camp
Re: Creating a mosaic transition
on May 13, 2014 at 10:35:46 pm
a basic block dissolve is pretty simple, there's an effect with that name in effects>transitions. you'll just want to set the block width and height to be fairly large (like 50-100px), uncheck the option for soft edges and animate the completion property.
however, the example you have starts with a basic block dissolve, then then does a left-to right block-like wipe.... if you need that, that's a little trickier.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
