After Effects Shapes - Start Scale and End Scale??? To make branches from strokes?
Jhem Murray
on Aug 30, 2012 at 5:31:21 pm
Hi
I can't see any option to separately scale the start and end points of a stroke shape, to create a sort of branch or tentacle effect...I refuse to believe it doesn't exist...Basically I want my stroke shape to start out thick but then get thinner towards the end...Is there any expressions I can use to resolve this problem?
Thanks a lot in advance
I just can't believe they have all those options but nothing to perform such a simple task of course I may be wrong
Dave LaRonde
Re: After Effects Shapes - Start Scale and End Scale??? To make branches from strokes?
on Aug 30, 2012 at 6:34:21 pm
Look into using AE's Write-on effect. It should do the trick.
Dave LaRonde
Sr. Promotion Producer
Vishesh Arora
on Sep 2, 2012 at 4:10:37 pm
Mr. Murray
You can use Write-on effect to make branches from stokes as Mr. LaRonde has said.
Here is the link for tutorial:
Also to make branches look more organic, try to use "Liquify effect".
Vishesh Arora
VFX and Motion Graphics Artist
http://digieffects.wordpress.com
