GPU render settings?
Michael Garske
on Aug 29, 2012 at 6:06:14 pm
In After Effects 5.5 I thought there was a check box to enable GPU rendering under the render setting dialog in the render queue. I just recently got CS6 and I don't see anyway to enable GPU rendering in render settings. I want to compare rendering on the CPU vs. the GPU.
Does AE default to rendering with the GPU if it's capable? Are there any settings I'm missing to toggle GPU/CPU rendering or otherwise control that?
Angelo Lorenzo
Re: GPU render settings?
on Aug 29, 2012 at 7:55:21 pm
I think it may also be used in the viewer as "fast draft".
As to how it's controlled now in the output module, I'm not sure. OpenGL output was usually draft-quality only and not suitable for final output.
Angelo Lorenzo
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
© 2018 All Rights Reserved
