Shatter Effect: undesired transparant sides
Geoff Vane
on Aug 29, 2012 at 1:36:53 pm
When I type some text, and make it explode with shatter, the extruded pieces have a transparent side where you can peek into the piece. This is due to the transparency surrounding the text.
Is there a way to have solid shattered pieces with transparent areas around it, but where the sides are solid?
I can use the text itself as a pattern, but that gives text shaped pieces that do not explode into shattered pieces.
keith mcgregor
Re: Shatter Effect: undesired transparant sides
on Aug 29, 2012 at 3:02:24 pm
What did you choose as your side layer?
-Keith
Vishesh Arora
on Sep 2, 2012 at 4:31:43 pm
Mr. Vane
Here is a tutorial on how we can use shatter effect in different ways. May be you will get your answer :
Vishesh Arora
VFX and Motion Graphics Artist
http://digieffects.wordpress.com
