Masking an effect
Lewis Costin
Masking an effect
on Aug 5, 2012 at 8:47:55 am
Hi. I am trying to limit Keylight to a section of my footage (my greenscreen) and I can't find a way to use a simple mask to do this.
Is there a way of using a mask to apply Keylight to only my masked area?
Thanks.
chris brett
Re: Masking an effect
on Aug 5, 2012 at 1:55:03 pm
Hi Lewis --
-- fairly new to this app myself ( so this might not work ) but have you tried opening an adjustment layer and applying mask and keylight to that ...
if that does not do the trick I think I would try pre-comping the job so far / making a copy / and applying keylight and mask to top copy ..
-- will be interesting to see what the others make of it
----- all the best --- chris brett --
Erik Waluska
on Aug 6, 2012 at 12:33:20 am
"I think I would try pre-comping the job so far / making a copy / and applying keylight and mask to top copy .."
Yep, that's what I would do.
Dave LaRonde
on Aug 6, 2012 at 3:45:07 pm
You can just create a mask on the footage, or animate a garbage mask if necessary. Within Keylight is the option to select that mask as an Inside or Outside mask.
Dave LaRonde
Sr. Promotion Producer
