Crashing?
Dale Kutzera
Crashing?
on Jun 20, 2012 at 10:30:06 pm
Is crashing common with AE 5.5? I'm on an iMac 3plus GB, 12GB RAM. I don't think my projects are that complex, but when I try to open them the next day the program crashes.
Dan Fredley
Re: Crashing?
on Jun 20, 2012 at 11:49:27 pm
Try turning on Caps Lock before opening your project. It's probably an effect that is causing the problem. Close all comps then turn Caps Lock back on. Then reopen your comps. Sometimes that solves it.
Dale Kutzera
Re: Crashing?
on Jun 25, 2012 at 2:17:32 pm
Thanks. This did the trick. Just have caps-lock on and it boots up fine.
