Proper composition settings to output to standard DVD
Ed Moran
on Jun 20, 2012 at 8:23:32 pm
I want to eventually burn a widescreen dvd. What should my settings be?
I know they talk about 480i and 480p but I am confused with the presets.
Ed
Tim Bentley
Re: Proper composition settings to output to standard DVD
on Jun 26, 2012 at 3:23:07 pm
There's really not enough information here - what software are you going to use to author (or simply build) the DVD? What's the composition setup? Either way, I wouldn't advise using After Effects to encode for a DVD - just render at the same settings as the original, and use a dedicated compression application.
http://timbentley.info/films.html
