How to utilize stylish wipe transition with alpha?
Cassidy Clawson
on May 11, 2012 at 11:34:11 pm
Hello all,
I would like to use this transition to wipe between two clips.
http://www.pond5.com/stock-footage/10877277/transition.html
It has an alpha channel, and as you can kinda see, the burn is never totally opaque. I would like to try to use this to wipe between two clips... how would you guys do it?
My first approach was to simple fade the first clip to black as the transition wipes, then, in premiere, use a carefully timed additive dissolve to fade to the next clip. The results are decent I guess. I think it can be better.
What would YOU do?
John Cuevas
Re: How to utilize stylish wipe transition with alpha?
on May 12, 2012 at 1:39:09 am
Try a dissolve the same length(or a just a few frames shorter) as the wipe and set the wipe to add.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
