Motion path + bending along path?
Ryan Hill
on May 8, 2012 at 7:36:19 pm
For an example, what if I had a bunch of little pictures of tadpoles, and I wanted them to follow motion paths? But, since they are tadpoles, they should bend to match the bend of the path they are following?
What should I use? I could animate a "bend" effect on each of them, but there are supposed to be a whole swarm of them, I would obviously hope for a simpler method.
Dan Fredley
Re: Motion path + bending along path?
on May 9, 2012 at 5:06:01 am
How about just animate one in a precomp flipping it's tail back and forth in a loop and then use it as a video sprite in Particular to create the swarm?--if you have Particular, of course.
Another way would be to just have it "Orient along path" instead of "bending". Still might give the effect you are going for.
Layer>Transform>Auto-orient>Orient along path
Dan Fredley
Ryan Hill
on May 9, 2012 at 5:38:15 pm
I have a swimming motion in a loop, but I was hoping also to have it bend to the left or right when it's turning left or right.
