How to render without showing paths?
Taylor Fahlman
on May 6, 2012 at 7:09:40 pm
When I render, for example a title screen in 3D, it shows the little path markers that the text will follow, or a little box in the upper left with a particle generator. How do I make these invisible in the final render?
Tero Ahlfors
Re: How to render without showing paths?
on May 8, 2012 at 4:13:22 am
Motion paths and maskas will not show up in the final export. If it's a plugin that is in a trial mode it might have some watermarks when you render out.
