hide masks
Matthew Beall
hide masks
on Apr 27, 2012 at 4:08:08 pm
I have a layer with about 12 masks on it.. Can I hide all but the one I'm working on? I keep pulling the wrong points..
Kevin Camp
Re: hide masks
on Apr 27, 2012 at 4:38:25 pm
i don't know of a way to hide them (like soloing a layer), but you can lock the masks you aren't working with to avoid changing them.
you can also color code them -- clicking the colored square next to the mask in the time line will bring up a color picker to change the color of the mask path.
you can also set ae to automatically set different colors as you add new mask paths in the appearance preference (check the option for 'cycle mask colors'). it will only effect new masks, not the existing masks, but you might want to enable that option as you continue...
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
John Cuevas
Re: hide masks
on Apr 27, 2012 at 4:50:23 pm
Lock the masks you want to hide, then go to Layer -> Mask -> Hide Locked Masks
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Kevin Camp
Re: hide masks
on Apr 27, 2012 at 8:33:39 pm
excellent.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
