Shortcut to switch the the next composition?
Roger Alexander
on May 19, 2014 at 7:01:23 pm
I primarily work in Sony Vegas and then export clips to after effects for special effects. for a given music video I might edit around 20-30 clips in after effects. I open a new composition for each in AE and export them. I'm looking for a quick way to navigate between compositions other than using my mouse to scroll and find the comp and then click. This is particularly annoying when I need to send each comp to the render queue because every time I press Ctrl + M, it sends me back to the first comp of my project and then i have to scroll again and find the next one.
is there a shortcut to switch to the next (or even to another) comp in my project with a button?
Todd Kopriva
Re: Shortcut to switch the the next composition?
on May 19, 2014 at 8:56:17 pm
Shortcuts are all here:
http://helpx.adobe.com/after-effects/using/keyboard-shortcuts-reference.htm...
There are shortcuts for cycling through compositions and such toward the bottom of the "Panels, viewers, workspaces, and windows (keyboard shortcuts)" section.
After Effects team blog
Billlo bi
on Apr 3, 2016 at 11:55:24 am
just press "Alt + Shift + ," Or "Alt + Shift + ."
