Building a composition for both NTSC and PAL
Melanie Keyzor
on Apr 11, 2012 at 2:18:10 pm
Hello,
I'm about to start an animation (no footage) project where the output needs to be both NTSC and PAL. Is it better to build in NTSC and drop frames when rendering to convert to PAL or the other way? I would assume its better to drop frames but would this lead to a juddery animation?
Found a similar topic here but the answer wasn't clear
(http://forums.creativecow.net/thread/202/876490)
Any help would be much appreciated!
Mel
Dave LaRonde
Re: Building a composition for both NTSC and PAL
on Apr 11, 2012 at 5:13:24 pm
Unless your comp contains ABSOLUTELY NO footage with a frame rate such as video, image sequences or film scans, don't do it. You would only be making trouble for yourself.
Perhaps you can discuss the nature of this animation, and delivery specifications beyond mere PAL & NTSC. Things like H&V resolution, for example. The advice will get better.
Dave LaRonde
Sr. Promotion Producer
