Which is best for today's TV's? Upper, Lower, or None on field int
John Delmont
on Apr 6, 2012 at 5:41:25 am
Which is best for today's TV's? Upper, Lower, or None for the field interpolation when making a movie. I just did a project with some imported photo and some of them were strobing. Thank for the advice.
John Cuevas
Re: Which is best for today's TV's? Upper, Lower, or None on field int
on Apr 6, 2012 at 1:34:35 pm
The answer depends on what system you are going to be using for playback, HD-Upper. Standard Def-Lower. Computer-progressive.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
