Convert after effects project from ntsc to pal no footage
Roger Burton
on Apr 5, 2012 at 7:05:38 am
Hi chaps, I have been handed an ntsc project and I am in pal land - there's no 'footage' so there's no problem with interlacing or frame rate (ie it's only 'graphics') - the problem is the project has one 'main' comp in which are over 30 'pre-comps' will I have to go through all the pre-comps and change there comp settings from 29.97 to 25 fps as well as the master comp ... any advice very welcome (whilst I know this won't take me that long to do I really want to know if there are any dangers doing it before I hand the project back to my client) !
Roger
Dave LaRonde
Re: Convert after effects project from ntsc to pal no footage
on Apr 5, 2012 at 4:01:15 pm
That would depend on whether certain portions of the animation must absolutely, positively take place on a frame instead of someplace during a frame: a lightning bolt that has to sync up with a sound effect later in an NLE, for example.
If yes, the unmatched frame rates of the nested comps would almost surely throw off careful timings.
Dave LaRonde
Sr. Promotion Producer
Roger Burton
on Apr 5, 2012 at 4:03:12 pm
Thanks dave, that's good point and one I hadn't considered but I will now ... Roger
