Still images duration to comp duration
Nick Smith
on Mar 27, 2012 at 10:39:44 pm
Hi
I'm new to AE5.5 so please bare with me..
The problem. I have an audio track that lasts approx 3mins 50sec and 107 still images(jpegs) of differing dimensions that I want to add, as a sort of slide show. Is there a time-saving method of adding them, as a sequence, making each still last about 2.3 seconds, to cover the length of the audio track.
Cheers
Nick
PS If this has been covered, accept my apologies and please point me in the right direction..
John Cuevas
Re: Still images duration to comp duration
on Mar 28, 2012 at 12:03:00 am
Create a new composition the length of your music track in the dimensions you need. Take all your photos and drop them into your composition. Move forward 2.3 seconds, which is about 40 frames. Press "Cntl + A" to select all your pictures, now press "Alt + ]" to set the end point for all your pictures.
And to make things really easy, go to the Animation Menu -> Keyframe Assistant -> Sequence Layers. If you select no overlap, you will cut between each picture. You can choose to dissolve also, but it will change your math a bit.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Nick Smith
on Mar 28, 2012 at 8:45:30 am
Hi John
Many thanks for your help. Saved me a lot of time.
Cheers
Nick
