3d axis not visable
Ron Pestes
3d axis not visable
on Feb 27, 2012 at 8:00:33 pm
When I click the 3d icon in the timeline the tutorial says I should see red, green and blue arrows in the composition. These do not show up. What have I missed?
ronpesteshdvideo.com
Apple Certified Master Pro FCS 2
Sony EX-3
MacBook Pro
Dell M6600
New convert to Adobe CS5.5 Production Premium
Dave LaRonde
Re: 3d axis not visable
on Feb 27, 2012 at 8:23:24 pm
Is the layer in question highlighted? That's the only way you'll see those arrows.
Dave LaRonde
Sr. Promotion Producer
Ron Pestes
on Feb 27, 2012 at 9:05:11 pm
Yes, it is highlighted. No arrows in the composition.
Sony EX-3
MacBook Pro
Dell M6600
Dave LaRonde
on Feb 27, 2012 at 9:14:41 pm
Are you looking at the layer in the Layer window rather than the Comp window? It opens when you double-click on a layer.
If you're sure you're in the comp, you may have just turned off their visibility. On the side of the timeline there should be a little wing-out button; I believe there should be a command in there to turn it back on. I'm not in front of my AE machine to check.
Dave LaRonde
Ron Pestes
on Feb 27, 2012 at 11:32:58 pm
The arrows show up on the lower left side but the tutorial shows them in the middle of the panel along with the anchor point. I see neither in the panel itself, just the arrows at the left lower edge. Visabilaty is on.
Sony EX-3
MacBook Pro
Dell M6600
Todd Kopriva
on Feb 28, 2012 at 9:28:01 am
There are two differnet kinds of 3D axes: those attached to a layer to show you which way it is oriented, and those associated with a viewer, to show you which way the world is oriented.
See this page:
"Show or hide 3D axes and layer controls"
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Darby Edelen
on Mar 2, 2012 at 12:26:08 pm
Check your view options. While in the Comp viewer (make sure it's the active pane) go to View > View Options and make sure that the upper section has its checkboxes in order.
Darby Edelen
