I'm having so much trouble
Ryan Gibson
on Feb 9, 2012 at 4:34:40 am
I'm animating still photos for a video project.
I've imported a scanned letter, blown it up with Continuous Rasterization and animated it. It renders just fine at 60 fps. Wonderfully smooth.
I upload it to YouTube and it turns into this:
The stuttering is horrible. Since YouTube converts footage down to 30fps, I tried exporting it to that. Nope. Didn't work. Still stutters.
Originally uploaded ProRes422, but found out that high quality like that can cause stuttering due to low network speeds.
So I tried it in Quicktime H.264 and also MPEG4 at 10,000 Kbps. Nada. Even tried adding motion blur. Nothing's helping.
Dave LaRonde
Re: I'm having so much trouble
on Feb 9, 2012 at 3:53:51 pm
You might want to look at YouTube's delivery specs and match them.
I have a slow connection, and nothing plays in real time. This is horizontal motion, and you could be seeing a phenomenon called Judder, a combination of motion and frame rate. There's not much you can do about it except change the speed of the motion or the frame rate; higher is smoother.
Dave LaRonde
Sr. Promotion Producer
ben g unguren
on Feb 9, 2012 at 4:54:18 pm
Yea, it's judder.
You need to slow it down, or at least vary the speed, maybe add in a little rotation on the Z axis (like the camera is rolling back and forth a bit), and you should probably add motion blur.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.com
Michael Szalapski
on Feb 10, 2012 at 7:22:46 pm
More on judder here: http://kb2.adobe.com/community/publishing/908/cpsid_90843.html
- The Great Szalam
