Applying render output settings to multiple clips
Spencer Tycksen
on Feb 1, 2012 at 8:20:07 pm
How to you apply render settings to several clips in your render queue at once?
John Cuevas
Re: Applying render output settings to multiple clips
on Feb 1, 2012 at 9:02:54 pm
After you have the in the render you queue, "Cntl+A" will select all the comps and you can change your render settings(Best, DV, Draft).
To change the output module select the title "Output Module:" now and now go the last one you want to render with the same settings and while holding down "shift" select "Output Module:" Now you can use the pulldown to change all the output modules of the selected comps.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Angie Taylor
Re: #AfterEffects - Applying render output settings to multiple clips
on Feb 2, 2012 at 8:56:56 am
It's also worth taking time to create Templates for your Render settings and Output modules. When you make a template it will appear in the selection drop down menu, making it easy to apply it to multiple items in the Render Queue. You can also choose it as a default render setting so that you don't need to change it every time.
In terms of Output modules, many people don't realise that you can add multiple Output modules to a single render que item. This means you can render a movie once, then format it for several different outputs, avoiding re-rendering it every time. Saves tons of time.
To do this, select the item in the Render Queue and choose Composition > Add Output Module. Adjust the settings as required.
BTW, you can move Templates to other machines, very handy if you are a freelancer like me, working on different jobs and different systems.
cheers,
Angie
Angie Taylor animation & illustration for television, film, web and devices
http://www.angietaylor.co.uk
Twitter: theangietaylor
Linkedin: theangietaylor
http://www.facebook.com/pages/Angie-Taylor/118378194869002
