Poor quality Tff/PSD in After Effects
Ryab Smith
on Jan 11, 2012 at 4:15:19 pm
I'm bringing in a file that is 2000x1000 into after effects, originally it was a tiff, but I separated the car from the BG and changed the format from CMYK, to RGB, and saved it as a PSD.
I bring it into after effects, and it is fine when I preview it from the project window, but when I bring it into a comp it looks like it's about 25 percent resolution.
Any thoughts
Erik Waluska
Re: Poor quality Tff/PSD in After Effects
on Jan 11, 2012 at 4:51:32 pm
At the bottom of the composition window, check that the resolution is set to "full" and the size is set to 100%.
Ryab Smith
on Jan 11, 2012 at 5:04:04 pm
For some reason it renders out fine to full resolution but, its pixelated when I am working on it. And it is set to %100.
Kevin Camp
on Jan 11, 2012 at 5:19:29 pm
there is a quality switch in the switches panel of the timeline (a check box that looks like a diagonal line). make sure that is set to 'best' (it should look like a smooth diagonal line).
also, if you have opengl enabled for previews (preferences>previews) uncheck the opengl acceleration option.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
