Two levels of motion
Bruce Anderson
on Apr 25, 2016 at 11:13:22 pm
I'm thinking this must be a really basic question. What I'm trying to do is have the outline of a pointing hand move across the screen with two levels of motion: the first level simply moves across the screen - I've done this already with keyframes and again with expressions.
What I want to add is a sort of jabbing emphasis to the hand as it moves - as if someone were saying "there!, there!". As this is going on, the net movement of the hand might actually be backwards for a few frames. How do I add that second level of movement? I'm guessing it has something to do with motion on multiple layers - or a more complex set of expressions.
Bruce
John Cuevas
Re: Two levels of motion
on Apr 26, 2016 at 1:14:33 pm
You could try parenting the hand to a null, and then keyframe the null when needed, I would try scale.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Bruce Anderson
on Apr 27, 2016 at 2:09:57 am
Thank you! I knew there was something really basic that I was missing - it was the parenting bit.
