How to change your green screen background
Tyler Smith
on Dec 29, 2011 at 10:31:01 pm
How can I change my green screen background in the editing process, to a different color like white,black, or purple. I know how to key out the green screen i just want to know how to change the color after i'm done keying out the green screen and leaving the subject still their.
steve agriosi
Re: How to change your green screen background
on Dec 30, 2011 at 2:39:56 pm
1. Find the hue and saturation filter
2. select the green input
3. shift it to the desired color.
U may have to control also some values for the :red / yellow/ cyan in order to achieve better results.
Michael Szalapski
on Dec 30, 2011 at 3:42:10 pm
If you've already done the key, you could just put create solid and make it the color you want and put it below your keyed layer.
- The Great Szalam
steve agriosi
on Dec 30, 2011 at 4:44:00 pm
in this case the key should be perfect.
Otherwise semi-transparent areas would reveal all the compression,
especially over a black background (in most cases)
So Tyler u r ok with keying i assume. Your question is all about compositing?
( placing the background layer below the keyed footage directly in ur editor )
If this is all about then Michael's advice is the proper one.
