How to make an even selection?
Ray Doll
on Dec 28, 2011 at 9:35:03 pm
This has been bothering me to no end. What is the key combo to make an even selection? In photoshop its shift+drag.
Dave LaRonde
Re: How to make an even selection?
on Dec 28, 2011 at 11:48:12 pm
I know very little about Photoshop. Exactly what kinds of things do you want to evenly select in AE?
If you make a mask on a layer, Shift-drag will keep a rectangular mask square, and an elliptical mask circular. Is that what you're talking about?
Dave LaRonde
Sr. Promotion Producer
Ray Doll
on Dec 29, 2011 at 5:06:00 am
Your post is correct - it does. I have found the solution: in After Effects CS5.5, to make an an even selection you use shift drag, BUT you have CLICK first, THEN press SHIFT (unlike in Photoshop CS5.1 and most Adobe programs, where you hold shift FIRST, THEN click and drag.) The order of operation is crucial, because in Photoshop you would want to depress shift first, then release the mouse button (if you don't do it this way, you risk messing up the selection). As far as I have figured out, in AE shift also deselects the layer or something silly like that, so shift then drag just ends up in frustration. However if you click, THEN shift, then drag, it works.
Phew.
Dave LaRonde
on Dec 28, 2011 at 11:48:31 pm
Dave LaRonde
Michael Szalapski
on Dec 28, 2011 at 11:54:44 pm
I don't know what you mean by "an even selection". In what context are you trying to do this particular selection?
- The Great Szalam
Tero Ahlfors
on Dec 29, 2011 at 8:58:32 am
The selection shortcuts should be the same in AE and PS.
