Unwanted transparency objects
eduardo asta
on May 28, 2014 at 12:35:02 am
Hello,
I'm trying to make a compo transparent but it keeps showing all objects inside of this composition, with, in this case, is weird. My compo has many footage I brought from AI.
What am I doing wrong?
My best
edo
Michael Szalapski
Re: Unwanted transparency objects
on May 28, 2014 at 1:08:02 pm
Do you have the collapse transformations/continuously rasterize switch turned on?
- The Great Szalam
eduardo asta
on May 28, 2014 at 5:49:47 pm
ohhh, I turned it out (the collapse...) and now I have a normal transparency...
many thks Michael!
edo
John Cuevas
on May 28, 2014 at 1:24:09 am
Could you post a screen shot of your timeline with the opacity property twirled open?
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
eduardo asta
on May 28, 2014 at 5:33:22 pm
Hello,
Thks for helping!
There you go...the image you asked
More: the collapse transformations/continuously rasterize switch is turned on...
Can you see the "monstro cae brasileiro 2002" layer? It is weird...I can see the objects inside of it...
And here we have the compo of this layer...
What do you think?
