How do I see vector handles?
Darren Ruddock
on Dec 19, 2011 at 4:49:48 pm
Hi there,
I want to use the tutorial below.....
http://ae.tutsplus.com/tutorials/motion-graphics/quick-tip-reflective-strok...
I can get my text in from Illustrator but can't seem to see the vector points as shown in the tutorial at 0:48. Any ideas what kinda file he is using??
Many thanks!
Kevin Camp
Re: How do I see vector handles?
on Dec 19, 2011 at 5:12:22 pm
if you are seeing points and/or vector outlines, then the paths have been copy/pasted from illustrator onto a solid in after effects.
importing an illustrator will only allow ae to ai vectors continuously rasterize (always remain sharp), but not actually edit the vectors themselves... (unless something has changed is version 5.5)
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
John Cuevas
on Dec 19, 2011 at 5:12:24 pm
I downloaded the project files and it looks like he created the text in Illustrator, copied the paths, made a solid in AE and pasted the paths.
You could also just use the text tool in AE, select the layer and under the layer pulldown choose "create masks from text"
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Darren Ruddock
on Dec 20, 2011 at 4:17:42 pm
Thanks guys!!
