Text leading not working correctly
Martin Schlesinger
on Dec 7, 2011 at 5:00:35 pm
I've had this issue for a while now, and not sure what caused it. The text leading in After Effects doesn't seem to be working properly. Hitting the enter key after typing a line of text results in a huge gap between the lines, even with 0 leading. I just tried the shift+control+alt trick to reset preferences, but no dice. Any suggestions? I've attached a pic to show what I'm experiencing.
Thanks in advance.
Sincerely,
Marty
John Cuevas
Re: Text leading not working correctly
on Dec 7, 2011 at 5:27:56 pm
Switch to the paragraph tab and change the second column to 0. That is the "Add space before paragraph" adjustment.
Johnny Cuevas, Editor
Thinkck.com
Martin Schlesinger
on Dec 7, 2011 at 10:33:18 pm
Doh! Well, now I know! Thanks for the fix John.
