text selectors multiple changes
Alex Udell
on Nov 3, 2011 at 8:16:30 pm
don't know why I'm having so much trouble with this....
Let's say I set up a text animation using selectors and offset that
takes $10,000
and each character zooms, spins, and fades in sequentially
so I set up my adjusted values on position, opacity, and rotation
and i set up my offset fine
now my brain breaks...
on that same $10,000
but later in time I want to give the characters a sequential vertical bounce...or a position change.
Now that I have already set a range selector and am using that with position....
how do I do further editing to the same text obejct?
Sorry if I'm dense...
Angie Taylor
Re: text selectors multiple changes
on Nov 4, 2011 at 11:56:30 am
Hi there,
To add a position bounce with it's own range selector . . . instead of adding a property to the existing animator. Add a completely new animator by clicking on the "Animate" flyout menu (as opposed to the "Add" flyout menu).
Hope this helps!
Angie Taylor animation & illustration for television, film, web and devices
Twitter: theangietaylor
Linkedin: theangietaylor
Alex Udell
on Nov 4, 2011 at 7:05:25 pm
Thanks ANgie...
I don't see an option to add a new animator as you describe....
but I can do it if I take my existing animator and duplicate it....
then I reset it and work from there....
thanks again!
© 2018 All Rights Reserved
