switch a composition from rate back from 29.96 fps to 25fps
jean mathis
on Oct 25, 2011 at 3:50:00 am
I just finished an animation the first part of it (its not totally finished yet)
I misunderstood my clients terms: he wanted a 25 fps comp
and I did everything in 29.96, of course when switch the comp back from 29.96 to 25 fps all keyframes
are not adjusted on the 25 fps. Is there a way to get this straight without doing the whole animation
again from scratch in a 25 fps comp?
Thanks guys...
Jean
ben g unguren
Re: switch a composition from rate back from 29.96 fps to 25fps
on Oct 25, 2011 at 7:57:03 am
If there isn't any footage, you can probably just get away with nesting your 29.97 comp in a 25fps comp. Heck, even if you have footage it might work.
The main problem with this approach is when you have precise masking going on (like for rotoscoping) -- on certain frames AE will choose a value that is between two of your keyframes (since the frames from a 29.97 comp won't line up precisely with a 25fps comp, likewise with keyframes), and that can cause troubles. But that's certainly the easiest way to do it IMO: Nest, change frame rate, render. Check for errors.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.com
jean mathis
on Oct 25, 2011 at 9:01:16 am
ok will try this thxs
Roland R. Kahlenberg
on Oct 25, 2011 at 10:23:16 am
There's a link to an updated script on the following link that should do the trick - http://www.aenhancers.com/viewtopic.php?f=3&t=873&hilit=keyframe
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia.
jean mathis
on Oct 25, 2011 at 10:47:40 am
Thanks Maestro!
Jean
on Oct 25, 2011 at 12:08:00 pm
You're most welcome Mr ZANG! Do let us know how the script works out.
Cheers
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia - Adobe ACE/ACI (version 7) & Mocha Approved Trainer - Imagineer Systems Inc
jean mathis
on Oct 26, 2011 at 8:47:54 am
Worked like a charm. Saved me a lot of trouble.
Infinite thanks.
Jean
