Is it possible to track a video this way ?
David Dinis
on Oct 19, 2011 at 4:46:31 pm
I'm sorry if this isn't the best forum to ask this but it seemed the most appropriate. Basically I want to be able to track something in after effects and make it a clicable video. Much like what this does : http://www.wirewax.com/ .
However, I'd like to 1 - Do it myself in after effects ( or any other application ) and 2 - Export the tracking data so that it can be used with other applications. Is this possible ?
Thanks in advance,
David
Michael Szalapski
Re: Is it possible to track a video this way ?
on Oct 19, 2011 at 6:56:38 pm
You can't make any interactivity in After Effects. You may be able to make use of the tracking data from AE in Flash (where you would be doing the interactivity.
- The Great Szalam
Todd Kopriva
on Oct 20, 2011 at 1:23:02 am
Here's an example of what Michael is suggesting:
http://blogs.adobe.com/keyframes/2007/10/creating_interactive_video_wit.htm...
The tracking in this example was done in After Effects and then the results were used in Flash.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
