Appwall
John Bernard
Appwall
on Oct 4, 2011 at 5:18:32 pm
Hi!
I'm new here. I'm trying to replicate the Apple Appwall wherein the app icons are randomly falling.
I'm kinda stuck with the squash and stretch part. I could do everything manually and animate each app icon, but it would take a lot of time if I would need to revise some parts.
Is there a way, or probably an expression, that would globally control the animation?
Kevin Monahan
Re: Appwall
on Oct 4, 2011 at 11:49:46 pm
You're going to need expressions for for bouncing and jiggling.
Hopefully, someone can point you to an expression that would be suitable for you.
If not, you can go to the Effects and Presets panel menu and choose to Browse Presets. You can then look in Bridge for Adobe After Effects > Templates and look for the Expression Sampler and open it. The project opens in After Effects with a number of comps that should give you an idea for the expression you'll need.
You can also ask questions on the After Effects Expressions forum: http://forums.creativecow.net/adobe_after_effects_expressions
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter!
John Bernard
Re: Appwall
on Oct 5, 2011 at 4:11:28 am
Okay, thanks! i'll try asking from the After Effects Expression forum.
