Needing some pro advice
Lisa Simonson
on Sep 28, 2011 at 7:55:59 pm
I've run into a snag with this shot.
Explosion reflection in goggles with slow dolly into C.U., one lens.
I've tried alpha mask w add blending mode , color key, track mats, gradient mask,lots of things, yet every time I render the explosion seems to float on top. Not natural looking, The explosions are alpha channels. Any tips or ideas? Is it OK to post a still?
ben g unguren
Re: Needing some pro advice
on Sep 28, 2011 at 8:12:26 pm
Is this a compositing problem, or it is a movement problem, or both?
If it's compositing, posting a still will be very helpful.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.com
Sean Mullen
on Sep 28, 2011 at 8:19:22 pm
Have you tried blending the bg of the goggles back over the explosion element? You could also track in a light reflection over the explosion as well. Like Ben said, it would be easier to identify with a still or clip.
Sean Mullen
Rampant Design Tools
Lisa Simonson
on Sep 28, 2011 at 8:31:28 pm
Here is a mock up I did in photoshop.
The mask isn't that difficult. Unfortunately there is a slight curve with the dolly in. When I animate the mask its really aweful. Like a bad rotoscoping job.
Sean Mullen
on Sep 28, 2011 at 8:37:15 pm
Ok I see. I'd recommend feathering your mattes and if you are hand tracking them, to do at least every 3-5 frames (if not every frame, depending on the move) I'd also lower the opacity of the reflection a bit, blending in the goggles more. Try also putting a slight blur on the elements you are compositing.
Sean Mullen
Lisa Simonson
on Sep 28, 2011 at 8:44:06 pm
Oh! So hand tracking should be more frequent it seems. I was hand tracking about every 15-20 frames. Probably why it looked so jumbled. Will lower the opacity and use slight blur.
great, thanks!
ben g unguren
on Sep 28, 2011 at 9:31:31 pm
A mocha track wouldn't take long and might make a big difference over hand tracking. Then again, hand tracking has a certain appeal to it as well. But if the child is making any kind of small movements, the hand tracking tends to miss it.
Ben Unguren
Sean Mullen
on Sep 28, 2011 at 9:33:47 pm
I agree completely, I rarely hand track. It's easier to remove keyframes from a Mocha track for a looser feel than it is to refine a hand track, in my opinion. Mocha should be able to attack this fairly easily.
Sean Mullen
