Render Track Matte
David Biederbeck
Render Track Matte
on Sep 25, 2011 at 1:47:44 am
So here is a really stupid question...
How do I render out a trackmatte.
I'm blocking birds in a video for a 3d track in PFHOE.
Angie Taylor
Re: Render Track Matte
on Sep 25, 2011 at 8:15:41 am
Not a stupid question at all.
1) Go to Composition > Make Movie.
2) In the Render Settings choose "Best".
3) In the Output module choose Lossless.
4) Click on the hyperlinked text "Lossless" to open the settings.
5) In the Video Output section, under Channels, make sure that RGB & Alpha is selected to output your movie with an embedded Alpha Channel.
6) If you want to output a matte as a separate file, choose Alpha.
If you are going to all this trouble it makes sense to also save this as a template for future use. Name it Lossless + Alpha. Then you can simply select it from the menu (or even make it a default).
Hope this helps!
Angie Taylor animation & illustration for television, film, web and devices
Twitter: theangietaylor
Linkedin: theangietaylor
© 2018 All Rights Reserved
