copy one plugin setting across multiple layers?
kit webster
on Sep 19, 2011 at 11:30:57 am
I am running a plugin that I have added to 80 seperate layers. There is one parameter that I want to edit but want to copy it to all the other layers. Can someone tell me how to do this?
Thank you.
Kevin Camp
Re: copy one plugin setting across multiple layers?
on Sep 19, 2011 at 4:16:51 pm
in the time line, select that effect property and 'copy', then select the other layers and 'paste'.
it should paste not only the selected property's settings, but also the entire effect, so you don't need to have that effect already on the layer. if you do have the effect on the layers already, then it should just paste the selected property's setting, including keyframes.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
