Efficient Dynamic link of multiple clips from Premiere Pro to AE for color correction
Steve Wood
on Sep 9, 2011 at 3:11:48 pm
I want to see all my clips from my PP project in one composition in AE with each clip showing separately. Everything I have seen so far is to link one clip at a time or render the sequence.
It there a way to look at everything as if I did the project in AE originally as I want to apply different correction layers to different clips? Thanks!!!!
Dave LaRonde
Re: Efficient Dynamic link of multiple clips from Premiere Pro to AE for color correction
on Sep 9, 2011 at 3:41:41 pm
[Steve Wood] "I want to see all my clips from my PP project in one composition in AE with each clip showing separately. "
Then don't use Dynamic link: import the Premiere project into AE. Make sure you have edit lock, meaning that no further changes will be made to the cut. If you don't have that yet, you're taking chances.
Dave LaRonde
Sr. Promotion Producer
