tracer bullet moving away
Lisa Simonson
on Sep 8, 2011 at 12:21:18 am
I'm trying to create simple tracer bullets disappearing into the background. As if they were moving away from you (POV) I found tracer bullet tutorials but none from that angle. can someone help?
Corlin Palmer
Re: tracer bullet moving away
on Sep 8, 2011 at 12:42:13 am
I would say just change the opacity of the tracer over time, so it will gently fade away
Michael Szalapski
on Sep 8, 2011 at 5:14:14 pm
What tutorial were you following that couldn't be adapted to a different angle? If you're using CC Particle World or Particular, it's really easy. If you're using Beam...well, it's also really easy.
Basically I'm asking: how are you creating these tracers?
- The Great Szalam
Lisa Simonson
on Sep 8, 2011 at 8:03:23 pm
hi,
Thanks for responding! I found it not too difficult creating a side view or even 3/4 view tracer. Not sure though how one looks as its moving away from you, straight on. Is it like a dot that gets smaller? i would like it to show some arch near the end as it fades into the distance.
I made a few tracers. One in photoshop and one using a solid with added glow. No problem arching them across screen.
Maybe I should try particle world. Will check that out, thanks!
Michael Szalapski
on Sep 8, 2011 at 8:45:33 pm
In real life a tracer is never actually shooting directly away from you. The gun is not at your eye level plus gravity and the angle at which you are firing all make a difference.
I know you're trying CC Particle World, I'd also suggest trying the Beam effect.
- The Great Szalam
Lisa Simonson
on Sep 8, 2011 at 8:50:13 pm
Thanks. I'm just now trying beam and its working out great!
