Batch Rendering With Variations
Zech Williams
on Sep 6, 2011 at 7:49:45 pm
I am working on a project where I need to around 1000 versions of the same clip.
I need the ability to render the comp, then change out two images and one line of text, and render it again.
By the end, I hope to end up with 1000 copies of the same video, but each one has a different image/text.
Right now, Im changing the images manually and rewriting the text, then adding it to a network render que. Is there any kind of script or method to make it easier/automated?
Thanks in advance.
Dave LaRonde
Re: Batch Rendering With Variations
on Sep 6, 2011 at 8:07:34 pm
this doesn't really sound like a job that should be done completely in AE.
There is a piece of software that will let you append a standardized clip to a custom open or close for example, creating a new clip. This sounds like something you really could use!
However, I've never used it and I forget the name. I hope somebody else does!
Dave LaRonde
Sr. Promotion Producer
