saving presets??
Jason Barton
saving presets??
on Aug 25, 2011 at 12:59:27 pm
i'm trying to create a presets folder that holds only my favorite presets that i use the most
will save me a ton of time having to go thru all the folders to reach the same 10-12 presets all the time
how can i create a folder and place my favorite factory presets in them?
Stefan Hinze
Re: saving presets??
on Aug 25, 2011 at 4:10:26 pm
i did it the other way arround - i added a number in front of the presets (in my case the "17fx" becouse my bussines runs under a 17 and everybody needs to get aware of the number... muahahah --> just kiddin)
SO: if i type a 17 in the FX-Search window, i get all my presets
hope that helps
Jason Mettler
on Aug 26, 2011 at 2:03:01 pm
You can create a special folder and move the effects into it. Find 'Computer/Program Files/Adobe/Adobe After Effects CS*/Support Files/Presets'
Put folder in here. You can run into trouble if you move a part of a plugin and not the whole thing (Optical Flares, etc.) so try them out as you move them.
Also to get a folder to stay near the top make its name like this:
__Folder Name__
© 2018 All Rights Reserved
