Question about superblacks and superwhites in AE 5.5
Bill Ravens
on Aug 8, 2011 at 1:15:39 pm
I've tried to search for an answer to this, but, it seems to be such a huge source of confusion that I can't understand what I've read.
My question relates to the color space used within AE 5.5. When bringing a Sony MXF file into AE, it is tagged with the YCrCb color space.I've imported a REC709 Color Bar pattern with pluge bars. No matter what I do, AE clips the pluge bars below 0%. If I import the same REC709 color bar pattern in to Media Composer, I can perform a CC to recover the super blacks. Because AE clips the superblacks when I import, I can't recover the shadow detail info.Even if I check "Preserve RGB" the superblack values are clipped.
Is there a way around clipping superblack and superwhite values?
edit: it would appear AE maps the imported color bars to RGB0-255, clipping values below zero and above 255. Media Composer imports the same color bars to RGB16-235, allowing access to the superblacks and whites.
Darby Edelen
Re: Question about superblacks and superwhites in AE 5.5
on Aug 8, 2011 at 8:34:15 pm
Are you working in a project that is set to a 32bpc color depth?
Darby Edelen
Bill Ravens
on Aug 9, 2011 at 4:11:20 am
no, this is a standard 8-bit.
Darby Edelen
on Aug 9, 2011 at 4:44:06 am
[Bill Ravens] "no, this is a standard 8-bit."
Touché, I should've phrased that differently: You should try working in 32bpc.
Darby Edelen
Bill Ravens
on Aug 9, 2011 at 12:12:49 pm
AHAH!
Many thanx, Darby! I'm not a wise-axx...just thickheaded, sometimes. That worked.
