Showing keys - not expressions
Synnøve Ludvigsen
on Jul 18, 2011 at 10:29:36 am
Hello good afx people
When I animate in afx I like to have a tide workspace, and usually hide away alot of layers and use the u shortcut to only show layers and parameters which are keyed. This time around the rigged characters have alot of expressions, which also show up when I press u.
Is there a shortcut which only shows keys, and not expressions?
Or is there a way to customize shortcuts?
Greg Burrus
Re: Showing keys - not expressions
on Jul 18, 2011 at 2:50:30 pm
Not sure if there is shortcut for just keyframes and no expressions since technically you have to have a click the stopwatch to add expression which is a key.
I like to use the SS shortcut that allows you to just show the items you have selected. But if you have a lot of selections then that might not help.
You can use this script to customize your shortcuts - or use the old method of editing the file your self explained in the tuts by aharon rabinowitz.
and I found this long list of shortcuts
hope this helps.
greg - Blog - Portfolio
© 2018 All Rights Reserved
