Keying in a colour
Sara Bon
Keying in a colour
on Jun 28, 2011 at 12:38:33 pm
Hello,
I've been asked to key out a very rough video of a person dancing in front of a green screen. However
due to the poor lighting conditions and the dancer being dressed in a blue t-shirt, I'm losing the upper part of their body.
Does anyone know if it is possible to key back in a colour?
Many Thanks,
Kevin Camp
Re: Keying in a colour
on Jun 28, 2011 at 2:59:11 pm
to try and better isolate the color rage that you need to key, you should try to use a junk matte, which could be as simple as keyframing a mask that follows the dancer. the tighter the mask is to the dancer, then more narrow the color range is that need to be keyed, and that can help keep the data that you don't want to key out.
also, there is a good tutorial for using auto-trace to create the junk matte here:
http://library.creativecow.net/articles/rabinowitz_aharon/junk_mattes.php
or, if you have cs5 or later, you might look for some tutorials that can show you how to use rotobrush for keying.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Sara Bon
on Jul 4, 2011 at 9:14:20 am
Thanks for your help.
