Adding more memory
Jerel Peterson
Adding more memory
on Jun 16, 2014 at 12:19:09 am
I've always read that adding more memory will speed up AE. But is that just for RAM PREVIEWS, or does it also speed up the final rendering?
John Cuevas
Re: Adding more memory
on Jun 16, 2014 at 12:53:00 pm
The big one, when rendering more RAM allows for more multi-processing. Which if you combine that with a large SSD drive for disk cache, AE will be able to pull those pre-rendered frames quickly into your final render.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
John Cuevas
on Jun 16, 2014 at 11:35:52 am
It can speed up final rendering, in multiple ways. Check this out: Improve performance
Thinkck.com
