Comps
Marc Lucas
Comps
on Jun 6, 2011 at 7:34:17 pm
If I duplicate a Comp then make changes to the comp the original comp gets changed to. Can I not just duplicate a comp and make it say version 2 and make slight changes so I have two different versions? I know I can copy the layers and then put them in a new comp and that won't effect this it just seems a bit strange the way it works.
Todd Kopriva
Re: Comps
on Jun 6, 2011 at 8:56:35 pm
There's a difference between duplicating a composition in the Timeline panel and duplicating a composition in the Project panel.
If you do it in the Timeline panel (which I suspect you are), then you're not really duplicaitng the composition; you're duplicating the precomposition layer. The new layer and the old layer both point to the same source item---a single composition.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Marc Lucas
Re: Comps
on Jun 6, 2011 at 9:39:46 pm
Sorry I didn't word the post correctly, yes I was meaning when I duplicate a pre-comp.
Dave LaRonde
Re: Comps
on Jun 6, 2011 at 9:51:36 pm
As long as you do it IN THE PROJECT WINDOW and not in the timeline, you shouldn't have any problems.
Dave LaRonde
Sr. Promotion Producer
