Need Guidance with the Project
Anvay Nakade
on May 30, 2011 at 9:26:12 am
Hi everybody.My first post.
I need some guidance in conceiving the idea that I have in mind.
my idea is to create a composition where there are a series of photos and they start to play in a zoom out fashion and continues until the final picture comes out of the eye of the person.Sort of the vision of a person.
How to go about this in after effects?
Jason Mettler
Re: Need Guidance with the Project
on May 30, 2011 at 5:36:07 pm
That will be relatively easy in AE. Pre-comp your pictures and set up the move you want in Z-space. Then copy the keyframes to all the other pic comps and offset them according to taste/time. The last pic to move out of the eye you can fade out the transparency or zoom out to nothing over the face as you pull back. I might animate all the pictures to do the moving but, then, do a camera pull for the the face shot (and add in some depth of field).
charlie davies
on Jun 3, 2011 at 8:59:58 am
That move is covered in this tutorial, will just need a bit of tweaking
© 2018 All Rights Reserved
